Trunk light stays on
Discussion in 'Electrical Systems' started by Chiefs75, Apr 24, 2011.
  1. Chiefs75
    Chiefs75 Veteran Member
    134
    Mar 26, 2008
    Fort Rucker, AL
    I just noticed this the other morning when I got up to go to work. On my 8Z, the trunk light stays on even with the trunk closed. I read in one of the posts that this is a mercury activated switch. Is there a way to fix these or soeme other way I can clean/fix the switch up so it will work?
  2. dale68z
    dale68z Veteran Member
    1,388
    28
    May 14, 2009
    Peoria Arizona
    Sounds like it has gotten bent. Just bend the bracket till the light is off
    ,with the trunk fully closed.. Or, maybe someone has remounted it incorrectly.
