Trunk, quarters, wheelhouses replacement
Discussion in 'Body Restoration' started by Jeep43, Jul 13, 2020.
  1. Jeep43
    Jeep43 Veteran Member
    1,361
    54
    Mar 30, 1999
    Connecticut
    I am replacing my quarters on my 74. I have them off and am cutting the drop offs and outer wheel houses which need replacement too. Of course I found that the trunk floor is bad especially under the seam sealer and it too likely needs replacement.
    Is there any sort of bracing I need to worry about with this much metal removal? My trunk gutters are still in place bridging to the tail panel.
  2. steins70z28
    steins70z28 Veteran Member
    316
    54
    Apr 14, 2012
    Tulsa, OK
    The only thing you might consider is a support bar of some sort so you don't accidentally bend you trunk lips out of shape "down", the rest should present little problem as long as the frame rails and tail pan all stay intact.
