Trunk Weather stripping
Discussion in 'Body Restoration' started by NYLongshot, Mar 23, 2020.
  1. NYLongshot
    NYLongshot Member
    35
    Oct 13, 2014
    Boston MA
    Hi guys,
    Ready to install the new trunk weather stripping from Soff seal and wanted to make sure I put this in correctly. I dry fitted it both ways and to be honest I cant tell which is the correct orientation. Any help would be great.........
    Thanx
  2. COPO
    21,373
    2,789
    This weatherstrip is from GM which I purchased in 1985. If you have an aftermarket strip then it may differ.
    78B3F18D-3B45-490A-8624-A973282144C9.jpeg 8BF2B34D-0CA3-4F0E-B529-6DAC14D6C834.jpeg 5906214F-B2BD-4AFE-86F0-15077B9CEAA7.jpeg FCCE0C38-21A8-472C-9F7D-5C7173921616.jpeg 3B0B8949-B642-438C-BEA4-2932AE1AA0CC.jpeg C8B9A1F9-EDFA-4F0C-82EB-5C09B6E67C33.jpeg AC2020A0-B0C3-4533-AC00-5B01E0087F85.jpeg 543F5190-3606-4FEB-B9AE-704CAEC97874.jpeg 852DB1FF-8BFC-4DCD-AF94-8CC9678C9224.jpeg 5BDDD219-59F7-45F4-BD54-7DAFFAB99F55.jpeg
  3. NYLongshot
    NYLongshot Member
    35
    Oct 13, 2014
    Boston MA
    So which way do you think is closest to the factory set up? The seals I bought were from soff seal.......
  4. Twisted_Metal
    30,378
    3,003
    Correct.
    And the ends should meet at the bottom center.
    Weather strip adhesive should be used to seal the ends together.
  5. 76 camaro car 1
    76 camaro car 1 Veteran Member
    2,450
    39
    Apr 23, 2010
    St.Augustine,Florida
    High side should go outward.
  6. NYLongshot
    NYLongshot Member
    35
    Oct 13, 2014
    Boston MA
    So the last pic I posted is the correct orientation, correct? The one that shows an extra rib facing outwards........
  7. 76 camaro car 1
    2,450
    39
    Apr 23, 2010
    To be honest it looks like its upside down in the last picture. In your 1st picture the way it is on the left hand side looks correct. It should go like in my picture but mine has been compressed by the trunk lid for years. IMG_1371 (1).jpg The shark fin side goes up and points outward. If you reverse the direction in the 2nd picture I think you will have it.
  8. COPO
    21,373
    2,789
    I like the 1st and 2nd pic. The 3rd pic looks like it’s upside down.
    If I was in person then I could tell. Why the aftermarket can’t make it the same
    way GM did is beyond me. I guess China can’t reverse engineer.
    74Z28GC3 likes this.
  9. krabben1
    8,308
    88
    May 16, 2007
    ( . Y . )Delco
    Metro makes it right.
  10. NYLongshot
    NYLongshot Member
    35
    Oct 13, 2014
    Boston MA
    Hi guys,
    The first pic shows it both ways. On the left it leans towards the trunk while the right is the opposite. The last pic I believe is similar to what they show in the video. Attached is a profile pic of the install in the third pic above. Im thinking this is the correct way but just want to double check. Thanx guys...........
