serpent710
Trying to fine tune the Camaro. Hoping I can get away with giving basic info.
350 .030
scat crank
pistons,push rods, rockers all aftermarket
rpm air gap
Aluminum Heads
holley 650 dp 0-766651BL
I have it tuned so there is no hesitation or stumble when you hit the gas. At the same time the car after running for a bit will start to load up and the RPM starts to drop and go back up at a light. If I tune it so it idles good I get a stumble when I hammer the gas from a stop. let me know if I need more info to help. Thanks
350 .030
scat crank
rpm air gap
Aluminum Heads
