Turbo 350 shifts very hard
Discussion in 'Transmission & Driveline Topics' started by Z28zz383, Jun 18, 2020.
  1. larrywalk
    larrywalk New Member
    Dec 24, 2009
    St Louis, MO
    Lack of vacuum at the modulator will cause hard shifts at high rpm. Check for the presence of vacuum at the modulator. It may be a leak in the hose or use of ported vacuum - it should be full manifold vacuum.
    STUCKINCALI likes this.
  2. Z-Life
    Z-Life Member
    42
    12
    Oct 3, 2016
    Florida
    Look in to the modulator where vacuum line goes in, adjust the screw inside there.
  3. camaro71/holland
    1,320
    111
    Aug 27, 2003
    The Netherlands
    Just stick to a plan
  4. Cardinal
    8,300
    39
    Jun 22, 2003
    Endicott, NY
    What kit did the (I'm assuming) transmission shop use to rebuild it?
    Harsh shifts could be the accumulator and/or check balls left out.
