Turn signal switch & horn
Blown Camaro
American by birth, drag racer by choice
Dec 13, 2009
1,199
Deltona, FL
Fixing some more things on this old car. The turn signal switch no longer cancels correctly on right turns so that needs changing. Are you guys using GM switches or is there an aftermarket that works fine? I have a tilt column if that matters.
Secondly, the horn switch on my Grant steering wheel does not work. The little spring contact exploded. What do I need to fix this? An install kit? I can't remember as it has been 15 years since I installed it. Have you guys upgraded your horns? I want something different.
Thanks!
spoonLT1355
5,511
Rockledge Pa
for the turn signals, you will not need a switch, you need a little spring that breaks . Look in my signature and you will see how to fix this. As for the horn, depending on what broke, if you see the part in my link, let us know.
