Turn Signal Switch issue
Discussion in 'Troubleshooting & Diagnosis' started by Steve's 74, Mar 25, 2021.
  1. Vettenick
    Vettenick Vettenick
    350
    67
    Jul 17, 2019
    Does the dash light come on, but does not blink? If so, check the bulb and socket first.
  2. Steve's 74
    Steve's 74 Veteran Member Lifetime Gold Member
    2,752
    Dec 29, 2003
    Long Island, NY
    It blinks.
  3. Vettenick
    Vettenick Vettenick
    350
    67
    Jul 17, 2019
    Then I would check the turn signal bulb/socket area first. One other thing to try is to swap both front bulbs. If the problem moves to the right, then it is the bulb.
  4. Steve's 74
    2,752
    Dec 29, 2003
    Long Island, NY
    This morning I swapped the bulbs, cleaned the contacts, and tested all the lights including flashers. Everything is working except that front drivers signal in the fully depressed mode. One other note; it's both the side marker and front signal bulbs that don't come on in the fully depressed mode. (And I'm sure they're pigtails somewhere close to the bulb end.) Which brings me back to the switch as the problem.
    I don't mind pulling it apart to inspect. But weather is finally getting nice here and it's driving time. Hard to do without a steering wheel on there.:bowtie:
  5. Steve's 74
    2,752
    Dec 29, 2003
    Long Island, NY
    So before I pull the the steering wheel off I'd like to have the replacement part on hand.
    Is it the 10 pin, 3 7/8" wide connector? RockAuto list this as OEM / alternate #: 1893588
  6. mallard
    mallard Veteran Member
    1,332
    415
    Oct 3, 2013
    SK, Canada
    From the OP's description it does not seem to be a bulb or socket issue. I think the posters blaming the turn signal switch are bang on. If you have any access to a "known" good switch, you could try plugging it into the receptacle on the steering column and see if it behaves correctly.
  7. Vettenick
    Vettenick Vettenick
    350
    67
    Jul 17, 2019
    That's the only one that's listed. It might come with an adapter harness. Good luck!
  8. K1ng0011
    K1ng0011 Veteran Member
    192
    31
    Mar 22, 2014
    United States
    Not sure what year your car is. I have had blinker issues before. On the 1970-73 models with the lower fog light position blinker the bulb grounds through the housing and the housing grounds to the frame. Later years have a dedicated ground wire for the bulb itself. If your blinker housing is rusty or the mount point to the frame is rusty weird things can happen without a good ground. If you look up the painless wiring harness document for our cars it illustrates what I am referring to.
  9. Steve's 74
    2,752
    Dec 29, 2003
    Long Island, NY
    I really doubt it's in the socket or bulb considering it all works perfect in the lane change mode. I ordered the switch from Ricks (Ecklers). No ETA yet, but Hopefully it's the correct part;
    Camaro Turn Signal Switch, 1970-1976
    Part #:: 33-171290-1
  10. Stelan
    Stelan Member
    33
    16
    Mar 20, 2020
    it's probably the switch, you can just put a little wire jumper from the yellow wire to the light blue wire at the harmonica so all left signal/blinkers work at the same time and circuit (which is what most cars are)
