Turn Signal
Discussion in 'Troubleshooting & Diagnosis' started by Radical Z, Sep 13, 2021.
  1. Radical Z
    Radical Z New Member
    May 28, 2019
    Turn signals (left and right) are not blinking. Where do I start to determine the problem .
  2. MChamp
    MChamp Veteran Member
    221
    60
    Jun 6, 2021
    north carolina
    what year?
  3. Radical Z
    May 28, 2019
    1973 Z
  4. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    287
    229
    Feb 5, 2016
    Sarasota,FL
    what do your left and right indicators do when activated.
    Off, stay lit. do both act the same?
    Does the emergency flasher work?
    Turn on each turn signal and check the front and rear bulbs for any activity.
    Possibly multiple bad bulbs. Corroded sockets, bad flasher.
  5. MChamp
    221
    60
    Jun 6, 2021
    north carolina
  6. Radical Z
    May 28, 2019
    Left and right indicators light up but do not blink.
    My emergency signals do flash.
    All exterior signal lights light up when turned on
  7. Twisted_Metal
    29,962
    2,715
    Sounds like a bad flasher issue,
    There are two flasher units in this system…
    One for signal lights and one for emergency flashers.
    The signal light light flasher is on a pigtail under the dash.
    (Emergency flasher is in the fuse block.)
    Switch them around to see if the problem follows the flasher.
  8. Radical Z
    May 28, 2019
    It was my flasher. Thank you all for showing love.
    MChamp likes this.
  9. Twisted_Metal
    29,962
    2,715
    Glad it was the simple fix! :D
    Messed up wiring (or a swap to LED bulbs) can be a much bigger challenge when it comes to signal/hazard light circuits.
    MChamp likes this.
