Turning engine by hand
Discussion in 'Engine Topic' started by LoweRider, Nov 4, 2021.
  1. LoweRider
    LoweRider Veteran Member
    120
    32
    Jun 26, 2017
    TX, USA
    Fully assembled engine minus flexplate, tried removing the crank pulley bolts but need an impact to remove them, weren't budging with a wrench and might have started stripped the bolt a little. Planned on using those bolts and a bar to turn it that way.
    Will it be ok if I go to the hardware store and buy some long 7/16-20 bolts and use a bar to turn the engine at the flexplate bolt holes?
  2. carhead22000
    carhead22000 oldblue
    833
    375
    Sep 5, 2011
    canada
    yes fine.remove plugs.
    LoweRider likes this.
  3. Zspoiler
    Zspoiler Veteran Member
    4,158
    501
    May 6, 2012
    Federal Way, Washington
    would prelube it as well.
  4. LoweRider
    120
    32
    Jun 26, 2017
    TX, USA
    Thanks guys, appreciate it
