Subframe Repair Kit for the 1970-1981 Camaro and Firebird P/N 2662 Priced at $39.99/kit UMI Performance, Inc. is pleased to announce the availability of our 1970-1981 Camaro and Firebird subframe repair kit. 40+ years of moisture and abuse can leave your frame in bad shape, and unable to properly locate the body mounts. Our 8 piece kit is designed to weld-in and provide a sturdy surface and a properly sized hole to restore the frame to a like-new condition. Cutting and welding is required. The 1/8” thick laser cut UMI P/N 2662’s are designed and manufactured in Philipsburg, PA-USA. ### Website link here.
Have a question on your kit. is UMI producing a kit for the earlier 2nd gen frames as well the later 2nd gen frames? there is a difference between the two.
This kit fits all 70-81, there is two plates you won't use depending on what year the car is. We have three of them here right now, a 71, 76 and a 78. The kit is able to work on all three of those years with two left over plates. Hope this helps.
