UMI Releases New Product: Tubular Front Lower A-arms for the 1970-1981 Camaro & Firebird
Discussion in 'Sponsor, Vendors & New Products' started by UMI Performance, Feb 9, 2017.
  1. UMI Performance
    UMI Performance Member
    74
    47
    Apr 11, 2015
    Philipsburg, PA
    Tubular Front Lower A-arms for the 1970-1981 Camaro & Firebird, Polyurethane or Delrin Bushings
    P/N 2651, Polyurethane, Priced at $599.99/set
    P/N 2652, Delrin, Priced at $659.99/set
    UMI’s 2nd Generation F-body lower a-arms are perfect for the F-body enthusiast seeking to improve the performance and appearance of their front suspension. The UMI new lower a-arms feature caster relocation of the ball joint to enhance steering feel and improve high speed stability. The heavy duty spring bucket accepts factory and aftermarket coil springs as well as the popular hybrid coilover units. Laser cut UMI reinforcement plates add a great appearance and excellent strength. UMI’s robust a-arms include greaseable, UMI designed and manufactured Delrin bushings for supreme smooth suspension action or polyurethane for street applications. Double shear swivel sway bar end links are included and work nicely with UMI sway bar P/N 4035 and also most aftermarket stock eyelet type sway bars. Available in UMI red or gloss black powder coat. 100% designed, manufactured and raced with pride in the USA.​
    Features:
    • Direct bolt-in for 1970-1981 GM F-body.
    • Lower ball joint relocated to increase caster by 2 degrees enhancing steering feel and straight line stability.
    • 1.500” USA Made DOM steel tubing construction.
    • Premium ball joints installed.
    • Heavy duty spring bucket accepts factory and aftermarket coil springs.
    • Spring bucket is compatible with popular hybrid coils such as Viking and QA1.
    • UMI Delrin bushings enhance steering precision and reduce friction for all racing applications.
    • Double shear swivel sway bar mounts and hardware work with UMI P/N 4035 and most other factory eyelet style sway bars.
    • Made in the USA.
  2. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    Scott from Hamilton, NJ
    Any reason these wouldn't these work with other upper arms?
  3. UMI Performance
    74
    47
    Apr 11, 2015
    Philipsburg, PA
    Hello, These would work with any upper. The UMI upper has 4-5 degrees of caster built in and works well with the lower a-arm to achieve around 6 degrees total while not moving the spindle pin. But other uppers would work as well.
  4. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    Nice. I already have SPC uppers and run about 5* I would think these might move the wheel forward in the wheel well a touch compared to stock LCAs.
  5. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,577
    1,043
    Mar 27, 2016
    NY
    Hi UMI,
    I am interested , what would be the discount for our members?
    Thanks
    jester0618 likes this.
  6. UMI Performance
    74
    47
    Apr 11, 2015
    Philipsburg, PA
    Yes, correct they will which would be good for you. Running 5* up top pulls the spindle pin rearward so the lower might center it nicely for you. 2* on lower and 4* up top gave us a nicely centered pin.
    [email protected] We can do free shipping in the US 48. We are happy to help. We have full kits I will be posted soon too, but are already on our site.
    Thanks!
  7. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    Cool, thanks. I'll add that to my list of upgrades :)
    UMI Performance likes this.
  8. Bandit723
    Bandit723 Veteran Member
    3,448
    576
    Oct 1, 2016
    Waupaca WI
    Do these require a special spindle or, can the stock ones be used
  9. UMI Performance
    74
    47
    Apr 11, 2015
    Philipsburg, PA
    These are designed to work 100% with the factory spindle. We do have tall ball joint options for adding spindle height but all our a-arms are designed around the factory spindle. Thanks for asking,
    Ryan
  10. UMI Performance
    74
    47
    Apr 11, 2015
    Philipsburg, PA
    Just let me know and I am glad to help. We also have our race oriented lowers we literally just finished... they have 5* in the lowers with quick removal coilover brackets :)
