UMI Releases New Product: Tubular Lower A-arms for the 1970-1981 Camaro & Firebird
Discussion in 'UMI Performance' started by UMI Performance, Feb 9, 2017.
  1. UMI Performance
    UMI Performance Member
    74
    47
    Apr 11, 2015
    Philipsburg, PA
    Tubular Front Lower A-arms for the 1970-1981 Camaro & Firebird, Polyurethane or Delrin Bushings
    P/N 2651, Polyurethane, Priced at $599.99/set
    P/N 2652, Delrin, Priced at $659.99/set
    UMI’s 2nd Generation F-body lower a-arms are perfect for the F-body enthusiast seeking to improve the performance and appearance of their front suspension. The UMI new lower a-arms feature caster relocation of the ball joint to enhance steering feel and improve high speed stability. The heavy duty spring bucket accepts factory and aftermarket coil springs as well as the popular hybrid coilover units. Laser cut UMI reinforcement plates add a great appearance and excellent strength. UMI’s robust a-arms include greaseable, UMI designed and manufactured Delrin bushings for supreme smooth suspension action or polyurethane for street applications. Double shear swivel sway bar end links are included and work nicely with UMI sway bar P/N 4035 and also most aftermarket stock eyelet type sway bars. Available in UMI red or gloss black powder coat. 100% designed, manufactured and raced with pride in the USA.​
    Features:
    • Direct bolt-in for 1970-1981 GM F-body.
    • Lower ball joint relocated to increase caster by 2 degrees enhancing steering feel and straight line stability.
    • 1.500” USA Made DOM steel tubing construction.
    • Premium ball joints installed.
    • Heavy duty spring bucket accepts factory and aftermarket coil springs.
    • Spring bucket is compatible with popular hybrid coils such as Viking and QA1.
    • UMI Delrin bushings enhance steering precision and reduce friction for all racing applications.
    • Double shear swivel sway bar mounts and hardware work with UMI P/N 4035 and most other factory eyelet style sway bars.
    • Made in the USA.
    Jason7504 likes this.
