underbody paint color
Discussion in 'Body Restoration' started by 73z28cam, Aug 23, 2020.
  1. 73z28cam
    73z28cam New Member
    19
    Feb 3, 2013
    Des Moines, IA
    can't make up my mind, on Satin Black or the original Red Oxide.
    less work if done in black, not looking for originality either, just cant decide
  2. x77-69z28
    x77-69z28 Veteran Member
    385
    33
    Feb 5, 2010
    long island, new york
    Seems you’ve answered your own question. If you are going assembly line correct, it’s red oxide. Then you have to add overspray while fully disassembled. It’s a lot of work! If you are not worried about original, satin black is the way to go. I just finished the underneath of my 70 Van Nuys Z/28. Since it’s a van Nuys car, it’s black underneath, but had heavy overspray! A lot of work is an understatement. Good luck whatever you decide!
  3. Rosster
    Rosster Veteran Member Gold Member
    263
    120
    Mar 1, 2020
    Is there any guidance as to where overspray would be?
  4. lapedr
    lapedr Veteran Member Gold Member
    650
    22
    Jan 28, 2003
    Pembroke, GA
    Who sells the red oxide?
  5. SPG
    SPG Bumblebee Builder
    848
    255
    Sep 1, 2018
    Sacramento
    SPI sells red oxide
  6. CamaroNmotion
    CamaroNmotion Veteran Member
    379
    36
    Jan 8, 2006
    Buffalo, NY
    If your car is a 73 (as your username suggests) red oxide is not the correct color you should be using if your looking to duplicate the factory in your restoration. Search the forums, this was discussed by 2nd gen years.
  7. grzewnicki
    3,505
    217
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Whichever you finally choose, I'd recommend the Southern Polyurethane Inc https://www.southernpolyurethanes.com/ epoxy primer. You can't beat the price. It's a good tough finish that will hold up well to the abuse the underside gets. It has a low sheen when dried. To give the wheel wells a little bit of added protection on top of the primer, I did my front and rear wheel wells with a trunk bed liner (UPOL), then when I still had some left did the trunk too. Make sure if you use SPI to read all their instructions on line pertaining to the epoxy. You can order on line and get it shipped right to your door. I used it on all the little bits and pieces, exterior brackets, interior brackets like dash braces and supports my subframe, and suspension pieces, All that stuff got a coat of black single stage knocked down with flattening agent to a semi gloss finish.
