Uneven exhaust PIPES OCD HELP!!
Discussion in 'High Performance Modifications' started by phantom69, Jun 29, 2021.
  1. phantom69
    phantom69 Member
    37
    Dec 16, 2020
    ok got a whole 3" x pipe setup with pypes performance that i love btw..had it as turn downs at first hated it! got it changed inmediately..new length extending to back with tips..decided the new tips "wicked flow" i wanted put on as they welded my first pipe passenger extension so they had to cut it a bit! my driver side is fine as they put that on after i decided on the tips but now i see my passenger side pipe is a lil bit shorter than my drivers side when lookin down the tips should i be concerned or im just being mental??
  2. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,977
    1,061
    May 21, 2014
    Hutto, TX
    I would take some measurements. The tape won't lie, but your eyes might. You'll know for sure then. Hopefully, the tail panel or something else is not tweaked.
    Zstar likes this.
  3. phantom69
    phantom69 Member
    37
    Dec 16, 2020
    tail panel is fine i love the way it looks its just the length of my passenger side pipe being a bit shorter if it adds something to the torque curve ill live with it but if the pipe is just longer for no reason i think i gotta have it cut to be exact to match the pasenger side
  4. G72Zed
    G72Zed Veteran Member
    3,039
    1,512
    Sep 8, 2015
    Don't worry about that small of length difference in that tail pipe area. Bends have more of an effect then length, within reason of course.
  5. Twisted_Metal
    29,897
    2,678
    I see options...
    1. Get another tailpipe from Pypes and have it cut the same way as the driver's side. (And remount the tip.)
    2. Shorten the driver's side the same amount.
    3. Don't sweat it. (Accept it as a unique quirk to your car.)​
  6. RMTZ28
    RMTZ28 Veteran Member
    198
    95
    Mar 29, 2015
    Alb. nm
    Stuff like that bothers me too. But sometimes i'll leave it a while and seems like not that big a deal. Or you can rent a pipe stretcher from autozone:brightide.
  7. Rustbucket350
    Rustbucket350 Veteran Member
    1,052
    90
    Sep 4, 2013
    Oviedo, Florida
    Cut the drivers side to fit or put some chrome tail pipe bolt on on. No big deal. It will not affect power in any noticeable way no matter what you do to the end unless you crimp it shut.
  8. Twisted_Metal
    29,897
    2,678
  9. phantom69
    phantom69 Member
    37
    Dec 16, 2020
    ha! no too tacky for my taste..i have to do something about it as i told them i wanted the pipes the exact same length before i decided on the tips they didnt measure the cut
  10. DougD
    DougD Veteran Member
    337
    117
    Dec 2, 2014
    Bradenton, FL
