United airlines catches on fire
Discussion in 'The BS Topic' started by SPG, Feb 21, 2021.
  1. doug mundahl
    doug mundahl Veteran Member
    166
    57
    Mar 31, 2020
  2. CorkyE
    11,217
    836
  3. doug mundahl
    166
    57
    Mar 31, 2020
    unless the planes loaded with bombs by your house.
    dcozzi likes this.
  4. Fbird
    5,363
    1,365
    Feb 12, 2011
    atlanta, ga
    i thought they just detached an engine to help the bombardier do calculations.....lol
    sooner likes this.
  5. 1980RS
    1980RS Veteran Member
    4,975
    1,512
    Jun 17, 2006
    MN
    A family member who works for Delta says some of the airlines are sending out their engines to be repaired overseas, and that's where the problems start they stated. There is no oversite here to make sure the work was done right. They should know as my relative is an engine inspector.
  6. Budz
    3,254
    298
    Mar 17, 2002
    Ashburn, Va USA
    I see it was headed to Honolulu. I just flew to and from Maui a few weeks ago on United, but none of the flights were on a 777. Just long boring flights compared to this one :eek:
  7. badazz81z28
    20,151
    1,279
    Alabama
    They don't do anything? In the AF our engines are ran across a test cell (un-installed), then when its installed in the aircraft there is an idle run required. The cowling isn't part of the engine, and it breaking up and fodding out the engine...isnt an engine issue. However, like all things...components in engines do fail from time to time. Todays engine are highly monitored and controlled by computers.
  8. BonzoHansen
    20,651
    1,746
    Jun 1, 2005
    Scott from Hamilton, NJ
    sooner, 1980RS and muscl car like this.
  9. SPG
    SPG Bumblebee Builder
    949
    303
    Sep 1, 2018
    Sacramento
    Perfect thing to see right before you start your flight
    sooner and carr911 like this.
  10. GREGS396
    GREGS396 Veteran Member
    2,460
    27
    Oct 16, 1999
    allentown pa
    While I don't doubt your experience with this, I do find it a bit overblown on the pilots part. I've been in the industry for over 40 years, and the weight difference of one person is minuscule looking at the big picture. The average passenger weight that they use is 170 lbs, and that's nothing given the overall takeoff weight of a commercial airliner, and certainly not enough to be critical enough to be a the difference of flying on a single engine. Passenger and baggage weights are all based on an average number, so there's already a margin of error with that formula. The weight of one passenger can be compensated by sitting on the ground for a few minutes and burning off additional fuel. I'm my experience, we would remove some cargo prior to removing a passenger. The only exception to what took place, would be if this was a smaller 19-35 seat commuter aircraft. The maximum takeoff weight of a commercial aircraft is several hundred thousand pounds. This 777 did land around 31k over its max structural landing weight, but it's not that uncommon during an emergency landing situation.
