upgrade to 350.CI.what could go wrong
Discussion in '1978 - 1981 Specific' started by WILLIAM FLYNN, Mar 5, 2021.
Tags:
  1. WILLIAM FLYNN
    WILLIAM FLYNN Member
    35
    Aug 29, 2020
    81 Z28 T-tops ,computer car ,if i swap to a 350,different carb & double the horsepower ,will it affect the car/computer?
    ive already pull the check engine bulb.
  2. Gary S
    23,812
    1,459
    You will also need a different distributor, and if the car has an auto tranny, the lockup torque converter likely won't work.
    You can keep the original carb, distributor, and computer and just swap the engine from 305 to 350 however.
  3. biker
    biker Veteran Member
    3,229
    1,408
    Dec 7, 2014
    Tires. If you upgrade to a good 10:1 350 with cam, heads, intake, headers and eliminate the computer controls, you will burn through lots of tires. That's what will go wrong.
    WILLIAM FLYNN likes this.
  4. WILLIAM FLYNN
    35
    Aug 29, 2020
    thx Gary,4speed car ,forgot distributor,thats a must!
    figuring like a west coast engine fully done
  5. RickM
    RickM Veteran Member
    618
    105
    Apr 16, 2004
    Gaithersburg, MD
    It all depends on the computer. Are you keeping it?
    If so you need to have the computer controlled carb and computer controlled distributor.
    You will also need to change the computers prom to match the engine. You will need a prom that is engineered for a 350.
    If you are ditching the computer just get a non computer carb and distributor.
    Also if you are ditching the computer you can remove the computer wiring harness, the computer controlled temp sensor, heat riser TVS switch and heat riser, egr solenoids, speed sensor and smog pump diverter valve and smog pump.
    Unless you understand how the CCC system works you are probably better off ditching it.
    RIckM
