Upgrading to a 383 stroker - short block recommendation needed
Discussion in 'Engine Topic' started by jzest71, Jun 10, 2020.
  1. jzest71
    jzest71 New Member
    May 8, 2014
    Baltimore, MD
    Looking at shops for a short block. First phase is to upgrade to a 383 short block. I'd like to continue using my current top end components which are stock double hump heads, and an Edelbrock manifold with a 650 cfm carb. Heads have upgraded springs, threaded studs, guides, and roller rockers for use with a Lunati roller cam (.476/.504). Would like compression to be 10.2:1. Future upgrades would be aluminum heads & EFI. I've had conversations with Raptor Engines in Portland, OR. Others I've looked at are CNC Motorsports in SD, Skip White Performance in TN, and CME in SC. Any feedback on these shops? As is typical, I'm on a budget build. Recommendations?
  2. muscl car
    23,099
    1,592
    Jul 8, 2001
    SoCal High Desert
  3. Scaleytail
    Scaleytail Veteran Member
    150
    30
    Jun 12, 2016
    North Aurora, il
    Very happy with my Blueprint 383.
  4. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,978
    176
    Jul 31, 2001
    Ft. Lauderdale, FL
    I bought a new GM ZZ383 shortblock, and new High Lift Vortec heads. All from Scoggin Dickey. I'm at 10.3 to 1. More like 9.8 to 1 probably with my old school head gaskets.
    It's kinda a one stop shop, no excuses, no bulls--t GM performance dealer in Texas. It's up to you if you want to Roll-The-Dice with some of those places, I didn't.
    https://sdparts.com/?gclid=EAIaIQobChMI0LaSp8_66QIVkIbACh3rNgjNEAAYASAAEgJWZfD_BwE
    The cost of Machine Shop work in South Florida is stooopid. They don't want to be bothered. This was a way better way to go for me.
  5. kenny77
    2,978
    176
    Jul 31, 2001
    Ft. Lauderdale, FL
  6. Lowend
    16,108
    1,085
    Mar 25, 1999
    San Jose, CA, USA
    Conventional Camel-Hump heads have 64cc combustion chambers. So a conventional 383 with flat-top pistons (with 5cc valve reliefs) will be ~ 10.6-1
  7. CorkyE
    11,215
    836
    They've probably been machined flat several times, so you're likely to have more compression than 93 pump gas can handle. Also, that old head technology just will not flow what a 383 needs. You might pick up some torque on the low end, but they'll run out of steam way before the engine does. If what you have is still running, keep it running while saving for a more complete updated engine package. IMHO
    2ndGenCrazy likes this.
  8. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    804
    53
    Aug 18, 2011
    Upstate New York
    CorkyE Very good advice...
  9. kenny77
    2,978
    176
    Jul 31, 2001
    Ft. Lauderdale, FL
    I've seen way too many examples of Vortec heads just blowing all the old school re-worked stuff away on the street
    G72Zed likes this.
  10. 1980RS
    1980RS Veteran Member
    4,971
    1,512
    Jun 17, 2006
    MN
    Try Ohio Crankshaft, I hear their stuff is pretty good for the price.
