Upper control arm measurment
Discussion in 'Pro-Touring F-Body' started by Turbo70Camaro, Oct 25, 2013.
  1. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    Hey guys I need the measurement from the center of the bolt hole to the very tip of the zirk fitting. I need to know if it will clear my turbo piping.
    Outlined in yellow, I am concerned with the pass side only.
  2. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    4 1/8"
  3. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    Thank you very much, now I just need to measure and see if the nut/zirk area is going to touch the turbo piping. If it does I may have to go to a heim ended control arm to cut down the distance.
  4. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    well the zerk would gain you 3/8" in the front and 5/8" in the rear we could make a set with the zerks on the top of the bushing but you would not be able to reverse the offset cross shaft.
    I also have some cross shafts that are 3/4 shorter on each end that I could make a custom set with.
  5. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    Well I def will have to remove the zirk that points to the front of the car to gain full clearance. Will this be a problem ? can I grease first then take it off and plug it ?
  6. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    well to give you the most clearance I would make you a set with the other cross shafts that are a bit shorter on the ends and put zerks on the bushing sleeves this way you would gain about 1" total
  7. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    Great. Check your PM box please.
  8. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    PM sent
  9. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    PM sent back Dave thanks.
  10. 79T/Aman
    2,628
    248
    Oct 7, 2004
    Dickson TN.
    check your PM
