Upper door trim
Discussion in 'Body Restoration' started by gg59c1, Oct 1, 2016.
  1. gg59c1
    gg59c1 Veteran Member
    114
    Apr 4, 2011
    NH
    Looking for the clean no trim look so I took the upper door trim off the door to find the studs that retain the trim. Anyone have any advice or pics on best way to remove the door studs ? The trim I removed is the optional wide stainless.
  2. grzewnicki
    3,578
    277
    Dec 9, 2009
    Gordon from Jacksonville Fl
    They are called Nelson studs and are welded on, the only way to get rid of them is grind them back. You could use a sawzall to trim it down closer to the door skin then finish up with the grinder.
