dgunther350
I just upgraded my factory radiator (aprox. 26" wide) to Summit's SUM-384003 (aprox. 32" wide) radiator and I'm trying to find an upper radiator that fits. I believe this new radiator is essentially the same size as the RPO V08 option that came with the Z28. It looks as if the factory hose was just a few inches longer, it would fit, but it's obviously too short now. Has anyone done this swap before?
Other than the need for a new hose, the fit so far is pretty good with the factory lower hose fitting nice. I had to purchase a new upper support (Summit#:SUM-G3920B) which also looks like it'll do the job.
- Engine is a zz350 GM crate motor
- New radiator has a 1-1/2" upper inlet
- Thermostat housing is also 1-1/2"
Thanks!
Thanks!
