Using a distributor shaft as an pre-oiling tool.
Discussion in 'Engine Topic' started by TDPalmer, Nov 26, 2015.
  1. TDPalmer
    TDPalmer Veteran Member Lifetime Gold Member
    823
    Apr 25, 2011
    Cave City, Arkansas
    The book I'm using to rebuild my engine says that I can use a distributor shaft as a tool to turn the oil pump to pre oil the engine. I am ready to stick the intake manifold on but before I do it says I need to pre oil the engine to make sure everything is getting oil.
    I have an old distributor that I can use but I do not know how much I need to take off. I have already taken the cap off but I figure I would have to remove the gear and such so it does not turn the camshaft.
    Can anyone tell me what all needs to come off and how to remove the items? Or is there an easier way to pre-oil an engine?
    Thanks
  2. NorCal_71
    NorCal_71 Veteran Member
    390
    15
    Jul 7, 2008
    Santa Rosa, CA
    Easiest way is to grind off the teeth of the distributor gear, and then remove the mechanical advance setup off of the top so that you can attach a drill to the shaft.
  3. badazz81z28
    20,548
    1,380
    Alabama
  4. camaro383
    camaro383 Veteran Member Lifetime Gold Member
    274
    Mar 15, 2006
    Atlanta, GA
    This couldn't be any more true. Just order one and use it. It is a great tool, very easy to use and you don't have to waste time fabricating and grinding. I had intentions of doing the same thing and just said screw it and bought one...it was the best thing I did...10 years ago. ha ha
  5. COPO
    20,782
    2,403
    I bought this from GM and it's used with the intake on. Works great.
  6. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Use Lubriplate to assemble engine.
    it will run several minutes without additional lube.
    Crank fully assenbled engine with a disabled ignition, when you have oil pressure reinstall coil wire.
    START.
  7. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Damn that's a nice tool.
    The one I got, from before I switched my stuff to dry sump was just a rod, that didn't cover the oil passage.
    I also got a cut up dist from someone, and it worked excellent.
  8. COPO
    20,782
    2,403
    Yup, that works and I have done it this way too.
  9. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,188
    127
    May 3, 2008
    Chesterfield, VA (Richmond)
    Same here. Made one years ago. I've used it on every motor I put together.
  10. OldCamaroNut
    OldCamaroNut Veteran Member Gold Member
    948
    Apr 27, 2005
    Rancocas Woods, NJ
    Instead of grinding, I removed the drift pin and the gear slid right off.......
