Using a screw driver to bad bearing
Discussion in 'The BS Topic' started by 80sz, Feb 17, 2021.
  1. 80sz
    80sz Veteran Member
    3,797
    679
    Feb 2, 2014
    Buffalo,n.y.
    Where do you place it? I never used the technique till today. Awd car on lift in gear, they had on spinning spindle, I couldnt hear anything but scraping . That’s how I was showed but feel I heard better by putting on caliper. I couldn’t feel driving or turning but customer says it’s bad . It has blizzaks on it and she is a state trooper. I say she driving her little van hard cuz said brakes pulse also but are almost new. I couldt get them to pulse either. It was 8* out considering
  2. COPO
    20,605
    2,315
    Using a screwdriver to bad bearing? To your ear?
    If the brakes are pulsating then the rotors are getting hot and warping. I would put them on a dial indicator then if off, turn them down. Look at the pads, I bet they are not wearing evenly. Either replace the pads or sand them down evenly on a flat surface. Make sure the sliding calipers are cleaned and lubed in the proper locations including the O rings. I would also make sure the castle nut is torqued to the spinning spec and backed off to the next flat. BTW cheap China rotors warp.
    80sz likes this.
  3. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    298
    154
    Jul 17, 2017
    New Brunswick
    Old mechanics stethoscope
    using a screwdriver to hear a bad bearing works you will hear before you feel
    Before vibration analysis equipment became readily available this was the normal way of finding bad bearings in industry, use a large screwdriver with a hard plastic handle no rubber, old craftsman screwdriver is good, place place blade on bearing housing, ear to end of handle and you will hear every noise in motors, pumps, fans etc. also works for steam traps if trap is working right you will hear the trap open and close, if hot and just hiss of steam trap is bad, you can also hear cavitation in control vales. Old mechanics stethoscope
    you can also check to see if a alternator is charging using a screwdriver, hold screwdriver to back of alternator if screwdriver is attracted to alternator. charging, if no or little attracted alternator is not charging.
    Bought this screwdriver when I started working July 1974
    PalmbchZ28, 80sz and 70-camaro like this.
  4. Mike N
    2,976
    688
    Jan 13, 2002
    Spencerport, NY.
    I usually put my stethoscope on a caliper hold down bolt to hear a bad bearing. I've often found that the further away from the bearing itself you listen, the more you'll actually hear.
    80sz likes this.
  5. 1978 Z/28
    298
    154
    Jul 17, 2017
    New Brunswick
    when I started working there were no mechanic's stethoscopes the new mechanic's stethoscope do work much better.
    80sz likes this.
  6. dale68z
    dale68z Veteran Member
    1,404
    39
    May 14, 2009
    Peoria Arizona
    I spin the wheel while holding on to the coil spring. Amazing how you can feel a bad bearing vibrating through the coil spring
    80sz likes this.
  7. 80sz
    80sz Veteran Member
    3,797
    679
    Feb 2, 2014
    Buffalo,n.y.
    Good tips, sorry for the misspelling on post. I could hear much better by setting on caliper. Each side sounded same , driver had a slight click to it. I couldn’t hear resting on spindle. I did use a craftsman.
  8. 80sz
    80sz Veteran Member
    3,797
    679
    Feb 2, 2014
    Buffalo,n.y.
    I’m getting a scope when snap on guy comes next
  9. John Wright
    15,172
    388
    Aug 9, 2002
    Rustburg, Va
    I use a 24" long 1/2" extension and the sound resonates well enough up that extension to help pin point bearing noises.
  10. COPO
    20,605
    2,315
