Using Heat to Remove Rusty Bolt
Discussion in 'The BS Topic' started by Flynt, Mar 1, 2021.
Tags:
  1. carhead22000
    carhead22000 oldblue
    460
    180
    Sep 5, 2011
    canada
    get carpet away..heat it up hot..then throw a cup of cold water on it.wack it good with a hammer b4 you start.
  2. gramps
    gramps Veteran Member
    1,771
    1,248
    Jul 5, 2009
    mankato, mn
    point is he can’t get the carpet out of the way, it’s pinched between the plate and the floor.
  3. xten
    xten Veteran Member
    4,085
    3,055
    Sep 24, 2014
    Pittsburgh, Pa.
  4. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,864
    570
    Aug 11, 2010
    erie, PA
    that will not need heated
    hit it hard with a decent air impact & it'll spin right out
    those bolts have oblong threads
    Mike N likes this.
  5. Mike N
    2,983
    693
    Jan 13, 2002
    Spencerport, NY.
    Dirt and rust??? I can tell that most of you guys don't live in the salt belt..... that's pretty clean by Western NY standards.
    Heat it up, back it out.
    John Wright and 351maverick like this.
  6. Coadster32
    2,232
    341
    Oct 2, 2013
    Milford,CT
    As mentioned...penetrating oil is helpful...cleaning up the thread that you will be twisting out of the hole is helpful. I would try an impact driver mixed with these two at first. If the torx head fails you, maybe you can have a friend tack weld a nut on the head, or just drill it out at that point. If you are concerned about heat and the carpet, putting a couple of layers of aluminum foil between the floor and carpet might help, or a skinny piece of sheet metal.
  7. Fbird
    5,521
    1,483
    Feb 12, 2011
    atlanta, ga
    PB blaster....then an IMPACT DRIVER....not an impact wrench...not a long wrench with pipe...but an impact DRIVER.
    It does 2 things simultaneously!
    1st it translates your hammer blow into a rotational movement (full stroke = about 1/4 turn)
    2nd it also HITS the bolt vertically (which has proven to be a GOOD thing on BAD bolts)
    another method as mentioned ...sort of ...is take a 4" grinder and grind OFF all the bolt threads sticking OUT OF THE NUT PLATE underneath. This will HEAT the bolt AND get rid of "unwanted" threads that must go back up thru the nut plate.
    Good luck....those things can be a real pita
    BillyDean7173 and Coadster32 like this.
  8. carhead22000
    460
    180
    Sep 5, 2011
    canada
    yeah i know, he can try to heat it a bit from bottom.hopefully he can get a little on it.just have to be carefull.
  9. biker
    biker Veteran Member
    3,430
    1,528
    Dec 7, 2014
    Yes. Make sure you have the exact right size torx and hit it hard with a good impact. Hard to find a decent air impact anymore. If you can borrow a big milwaukee cordless 1/2 impact, the bolt does not stand a chance.
    351maverick and carhead22000 like this.
  10. Bandit723
    Bandit723 Veteran Member
    3,524
    619
    Oct 1, 2016
    Waupaca WI
    Trick i have used is to tighten then loosen the bolt several times "back and forth rocking motion" along with PB Blaster.
