Using Heat to Remove Rusty Bolt
Discussion in 'The BS Topic' started by Flynt, Mar 1, 2021.
Tags:
  1. dcozzi
    dcozzi Veteran Member
    4,100
    1,081
    May 1, 2002
    Phoenix, AZ
    Yep, heat the underside and use an impact. Those bolts have a ton of green goo on them.
    carhead22000 likes this.
  2. tom3
    tom3 Veteran Member
    13,386
    981
    Aug 1, 1999
    ohio
    I'd bet the torx bit will break. Those bolts are super tight seems like and a bit of rust welds them in.
  3. Flynt
    Flynt Veteran Member
    868
    15
    Jul 9, 2003
    Alabama, USA
    I want to thank each of you for responding to my question about removing a rusty bolt. Thank you for all your help! I really appreciate your help!
    Jodi likes this.
  4. 8pack
    2,821
    225
    Aug 29, 2007
    Western, MA
    Maverick does this for a living so I suspect his recommendation is spot on....................
    If you don't have an impact wrench use a good solid breaker bar although thouse torx heads are a tough to keep the bit in straight with a long lever....
    351maverick likes this.
  5. Mike N
    2,983
    693
    Jan 13, 2002
    Spencerport, NY.
    I also do this for a living. Mav is pretty much spot on, but my recommendation of a little heat will help melt the Loctite and ease bolt removal without risk of stripping the head of the bolt.
    8pack, 351maverick and gramps like this.
