valve cover breathers
Discussion in 'Engine Topic' started by giggity, May 4, 2016.
  1. 80sz
    80sz Veteran Member
    3,919
    746
    Feb 2, 2014
    Buffalo,n.y.
    Thx copo!
  2. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Damn, that is a cool project. I'm too lazy, I just bought a small vented can.
  3. giggity
    giggity Veteran Member
    1,601
    401
    Mar 18, 2013
    Pearland, texas
    so your not using valve cover breathers at all, just a catch can with PVC?
  4. COPO
    21,041
    2,581
    Yes, plus I have the factory hose from the pass side cover to the air cleaner and the PCV is hollow with a small orifice.
  5. mrdragster1970
    7,821
    507
    Apr 12, 2007
    So instead of using a pump or header to create negative air, you used the pistons.
    The steel wool blocks the mist, so you are still clearing the block of a little contamination and pressure from blow by!!!!
    Again, excellent project, very smart way to fix one issue, without causing another!!!!!
  6. giggity
    1,601
    401
    Mar 18, 2013
    Pearland, texas
    Isnt that big tube from your valve cover to your air cleaner essentially a breather?
  7. COPO
    21,041
    2,581
    I guess. All it has in the breather is a flame arrestor plus the baffle in the cover on both sides.
  8. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I'm assuming you don't run a gauge????
    It might be a good test to run a sealed system.
    It would help keep the windage down.
  9. Orange71
    Orange71 Veteran Member Lifetime Gold Member
    3,792
    Jan 31, 2001
    Finksburg, MD
    Where did you get the hollow PCV valve?
  10. COPO
    21,041
    2,581
    GM used to sell lots for the trucks that were consuming oil, then someone told them to stop selling them.
    Search on GM's part number 12572717 fixed orifice PVC valve.
    http://www.gilfether.com/low-manifold-vacuum-pcv-for-chevrolet/428/
    Here are the P/N's for the fixed orifice PCV valve -
    - ACDelco #CV948C,
    - AC Delco #12572717.
    GM no longer stocks the PCV valve.
    Substitute for GM 12572717 fixed orifice PCV valve
    BWD PCV484
    FRAM FV410
    WELLS PCV371
    DEFENSE FV410
    AIRTEX 6P1241
    CARQUEST 76-2698 in Canada
    http://www.nastyz28.com/forum/showthread.php?t=296555
