Valve cover gasket grrrrr
Discussion in 'Original Drivetrain Topic' started by Allison Winn, May 2, 2021.
  1. masterpieceinprogress
    masterpieceinprogress New Member
    Apr 25, 2004
    kitimat,bc,canada
    I glued mine on to the valve covers with upholstery glue. Never leaked.Lasted for years
    KingofThings likes this.
  2. G72Zed
    G72Zed Veteran Member
    2,690
    1,260
    Sep 8, 2015
    Lol, yep, I say that’s a little too tacky.
  3. KingofThings
    KingofThings Veteran Member
    285
    87
    May 8, 2020
    Notice that you never see them full of an oily mess. ;)
  4. Willie Bifulco
    Willie Bifulco Member
    58
    13
    Apr 13, 2020
    Felpro worked great for me as well. Just ensure they're fastened correctly. My restoration shop didn't tighten the valve covers enough and leaked until I wrenched on them a bit.
  5. need-for-speed
    need-for-speed Veteran Member
    742
    16
    Feb 7, 2003
    Conroe, TX
    Bingo!
    Truth is, the old OEM cast iron heads do not have a machined surface while aftermarket head do. What is often attributed to "my awesome gaskets of choice" (on aftermarket heads) is really just due to the machined surfaces on aftermarket heads vs the crappy old rounded mating surface on the OEM heads.
  6. Savethefullbumpers1970
    Savethefullbumpers1970 New Member
    Apr 27, 2021
    I always use and have the best luck with thick cork gaskets. 5/16” or 3/8” thick. Thin layer of snot on the valve cover side and dry on the head side. Not a fan of rubber or metal strapped ones. If you don’t have a heavy hand you don’t need that IMO.
    Dave Nelson and KingofThings like this.
  7. Brian H.O. Cornelius
    Brian H.O. Cornelius Breeze
    Jul 1, 2001
    Bonaire, Georgia
    Convert and install studs (use lock washers/nuts) spray cork gaskets with permatex and install using torque wrench. Recheck torque after about a week. This should eliminate leaks in that area.
  8. Dave Nelson
    Dave Nelson Veteran Member
    5,161
    4,165
    Dec 19, 2003
    Vineland N.J USA
    This is the recipe I use, never had a leak.
  9. KingofThings
    285
    87
    May 8, 2020
    I have very old, as in original, M/Ts and using the blue FPs without issue and without sealants on stock heads.
  10. Bandit723
    Bandit723 Veteran Member
    3,473
    589
    Oct 1, 2016
    Waupaca WI
    Can't even fathom on how folks using rubber gaskets don't pick up on leaks. It's ok, i run the same crap heads that the rest of world does but the fiber gaskets are far more better than rubber.
