valve spring install height - 1.785 instead of 1.8 spec ok for comp beehives?
Discussion in 'Engine Topic' started by fstarocka, Jan 18, 2021.
  1. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    Have a set of comp beehives and an aftermarket alu head with a comp xr288 cam -
    Coil bind/etc issues aside i purely wish to know if such a small amount will be ok? Dont really want to cut the pockets if I can help it..
    I need spring locators cos the beehive is 7/8 (0.875) ID and the guide is about 9/16 (0.560) -
    The current install height is 1.845, if I use a spring locator (-0.060) ill end up around 1.785, 15 thou shy -
    will this be ok? Street 383 im building.. and im checking everything with digital calipers as the valve height micrometer is off low thousandsths..
  2. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    Ok - to quote lunati:
    " An installed height of +/- 0.020" is acceptable." https://www.lunatipower.com/valve-spring-tech
    Now - My guide OD measure 0.560, the beehive ID measures 0.875 - what retainer specs can I use? whats the tolerance with clearances, 20 thou as well? going to try get a match for the sizes but might be out slightly (too big of course).. the OD f the beehive lower is 1.33 or thereabouts-
  3. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    ok - so seems for my alu heads these fit the bill -
    COMP Cams 4705-16
    Outside Diameter of Outer Spring (in):1.300 in. (fits the beehive spring)
    Inside Diameter of Inner Spring (in):0.570 in. (fits bronze valve guide with 5 thou to spare)
    Locator Thickness (in):0.050 in. - PERFECT! will leave me at 1.795 install height :)
  4. 1320feet
    1320feet Veteran Member
    448
    198
    Oct 23, 2019
    Calgary, Alberta.
    What lift is your cam and what is coil bind ht of spring?
  5. fstarocka
    fstarocka Member
    67
    Feb 1, 2013
    Seattle
    cam lift is 520/540- coil bind on beehives is 0.8 or 9 iirc.. plenty - plus I have 50 over retainers.. ill be doing pv checks this week but managed to find "ok" locators, really wished i could get some 0.045's but couldnt find any.. strange that comp doesnt have a 0.040/0.045 offering.. so ill be 15 thou under at 1.785 for 1.8 spec on the beehives..
  6. 1320feet
    448
    198
    Oct 23, 2019
    Calgary, Alberta.
    I should have asked for valve lift. If your valve lift is .540, then 1.785 - .540 = 1.245. Lots of room.
