Variable compression engine to debut in 2018
Discussion in 'The BS Topic' started by CamaroMan79, Aug 16, 2016.
  1. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,206
    19
    Jun 10, 2001
    Selah, WA
  2. Lowend
    16,090
    1,079
    Mar 25, 1999
    San Jose, CA, USA
    I was reading about this earlier... it's an interesting idea. They are taking advantage of lower compression and more boost pressure (better cylinder filling) to get more power
  3. CamaroMan79
    5,206
    19
    Jun 10, 2001
    Selah, WA
    I just wonder about longevity with the added mechanical parts.
  4. Jimmac
    Jimmac Veteran Member
    614
    242
    Dec 24, 2013
    tucson az
    Probably a good idea when it works, but that just looks like more parts to go wrong. Like the direct fuel injection I think gm uses. Listen in to the garage talk radio on saturday mornings, they were saying how this good idea isnt such a good idea because of the carbon build up on the intake valve has to be cleaned every 3-5000 miles. Jim
  5. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    1,693
    69
    Oct 1, 2004
    Montreal (Living in Houston)
    ^ yup. Got nailed paying for that myself. I hear they are looking at installing an additional injector upstream of the intake valve that fires periodically to address the carbon buildup. The carbon buildup cost should be covered by them. They created the problem.
  6. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    4,123
    907
    Mar 13, 1999
    Brighton, MI
  7. Mike N
    2,972
    681
    Jan 13, 2002
    Spencerport, NY.
    Wonder what that's going to do for quench and flame travel if they limit how far the piston comes up to the head?
  8. bracketracer-78
    bracketracer-78 Veteran Member
    732
    67
    Sep 5, 2003
    Stevens, PA USA
    Would it be easier to control the dynamic compression instead of the static compression?
  9. danbrennan
    4,123
    907
    Mar 13, 1999
    Brighton, MI
    I believe they're doing that, too, with the intake cam phaser. They talk about using a quasi Atkinson cycle(late intake valve closing). Or a Miller cycle, if they have boost at that point.
