Very odd ignition problem and spark plug wire resistance values....
Discussion in 'Troubleshooting & Diagnosis' started by 70SSRS350, Jul 8, 2021.
  1. 70SSRS350
    70SSRS350 Veteran Member
    432
    Jul 30, 2010
    ITALY
    I ended buying the very same (just in red color), but there is still somethibg wrong...
  2. Vettenick
    Vettenick Vettenick
    366
    71
    Jul 17, 2019
    It seems that you've eliminated the ignition system. Are you sure the wires are in their correct firing order?
    If that's OK, then have you run a compression check to see if it's a mechanical issue?
    You didn't mention whether or not is was better/worse cold or hot?
    70SSRS350 likes this.
  3. 70SSRS350
    432
    Jul 30, 2010
    ITALY
    Wires are in correct position, double checked.
    Compression check done and it seems fine..
    Cold or warm seems to not affect.
  4. Vettenick
    Vettenick Vettenick
    366
    71
    Jul 17, 2019
    Your firing voltages look OK. No burn time info though. That being said, what makes you think it's ignition?
    70SSRS350 and 8pack like this.
  5. 8pack
    2,964
    313
    Aug 29, 2007
    Western, MA
    ^^^^^^ Time to check fuel……looks like you have spark….
    Fuel filter
    Fuel pressure
    Fuel pump
    Carb settings………..
  6. 70SSRS350
    432
    Jul 30, 2010
    ITALY
    At first I tought the problem was ignition, I found very odd ohm resistance values on my plug wires, so I focused on ignition... at this point I think it's something else...
  7. 70SSRS350
    432
    Jul 30, 2010
    ITALY
    This evening (in Italy) I did another test:
    With engine idling (bad as usual) I disconnected one wire at time on distributor (there was spark on distributor/wire when I disconnect).
    If I disconnected cylinder #2 or #3 or #5 or #8, it makes big difference on engine work.
    BUT
    if I disconnected cylinder #1 or #7 or #4 or #6, it makes very small or NO difference.
    Is not possible that (with new parts) 4 cilinders do not spark at all!
    My intake is an Edelbrock Performer (dual plane) and these cylinders are on the same plenum!
    This make me think about the carb!
  8. Vettenick
    Vettenick Vettenick
    366
    71
    Jul 17, 2019
    How do the plugs look compared to the others? It might be an intake air leak. The cylinders that did not make much difference would be a lot lighter than the other 4.
  9. MChamp
    MChamp Veteran Member
    400
    110
    Jun 6, 2021
    north carolina
    If you got a timing light, hook it to each plug wire as close to the plug as you can and observe the spark. I'm thinking either the petronix, rotor, or cap is bad..
  10. Vettenick
    Vettenick Vettenick
    366
    71
    Jul 17, 2019
    His firing voltage is 8-12 kv for every cylinder. Based on that, how can his primary circuit be bad?
