Ok thanks. Nice work.I used Belltech kit #4977 x 2 from Amazon. I wanted the long center pin bolts and coupler nuts. I ordered 2 kits (4 wedges) because of the design of the 12 bolt spring perches. I need to add a second wedge equal and opposite of the first wedge on the under side of the leaf spring so the shock mounting plates bolt up square to the axle spring perch. I drilled out a 3/8 nut to slide over the center pin bolt to act as a spacer. This allows the head of the center pin to protrude past the top aluminum wedge and act as a “locator” in the axle as originally designed.
