Vin Location 70' Big Block Camaros
Discussion in 'Original Drivetrain Topic' started by THNDER, Mar 12, 2010.
  1. THNDER
    THNDER Veteran Member Lifetime Gold Member
    1,765
    Mar 18, 2000
    O'fallon, Mo
    Just trying to get an idea, of where all the 1970 big block camaros have the vin stamped on the block. I have some conflicting info. Dale? David? others? Could you state assy plant and build date of car, and build date of engine? Thanks! Mike
  2. CamarosRus
    CamarosRus Veteran Member
    8,545
    148
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    1970 01C Norwood L-78
    Eng Assy Date is Nov 69' CKO Tonawanda
    Bellhousing Flange VIN stamped 105XXXXX
    Remember the Citrus Green LA built L-34 everyone wanted me to buy. Car is now in Calif
    VIN was stamped on Bellhousing Flange. If you want the specifics I'll try and find.
  3. 70L34
    70L34 Veteran Member
    369
    8
    Jan 6, 2004
    British Columbia
    1970 Norwood 04D car
    T0409CTX engine assembly
    vin on bellhousing flange
    - Dale
  4. gpm6367
    945
    80
    Feb 12, 2005
    New Joisey
    Check out the photos...
    ...posted by another forum member on page six of this thread for vin location...
    http://www.nastyz28.com/forum/showthread.php?t=179002&page=6
    A picture is worth a thousand words...
  5. THNDER
    1,765
    Mar 18, 2000
    O'fallon, Mo
    Thanks for the replies so far. Keep them coming! David Nelson?
  6. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    Chuck, what was the cowl tag date on this particular car.....
    My LA built L34 car also has the vin stamped down by the bell housing flange. My Cowl tag is O3B and the vin has all the same size characters including the #5..... unlike some later built LA cars that have a larger #5.
  7. Dave Nelson
    Dave Nelson Veteran Member
    5,156
    4,133
    Dec 19, 2003
    Vineland N.J USA
    Mike , Norwood O1C
    Block Casting 3969854 Date J159
    Front Pad T1217 CTW ON5O478O
    Same Partial On Bell Flange
  8. CamarosRus
    8,545
    148
    Feb 16, 2000
    David, Are you sure your VIN stamping does not have 10N5xxxxx ?
    numeral 1 stood for Chevrolet Motor Div.....0 for 1970 N for Norwood and so on!!
    I read your post again and see where you used word PARTIAL .................
    Mike, 1) How unusual for the number 1 to not be included in a NORWOOD Vin Stamping ?
    2) How unusual for a NORWOOD Camaro to be stamped on Bellhousing flange AND Deck ??????
  9. Dave Nelson
    5,156
    4,133
    Dec 19, 2003
    Vineland N.J USA
    Chuck , here is front pad stamp , I have no pic of back of block stamp, but I will try to get next time I have car in the air.
  10. THNDER
    1,765
    Mar 18, 2000
    O'fallon, Mo
    wow, this is good stuff, and not what I was expecting. Thanks Guys. Anyone else? Magic Rat? others? Please chime in. Mike
