Vin vs Trim Tag build date
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by millpondmonster, Jul 3, 2020.
  1. millpondmonster
    millpondmonster Veteran Member
    297
    Mar 6, 2012
    far enough out it takes 3 days to get a text messa
    I have a 73 TYPE LT.
    Vin shows a Apr-May build date.
    Trim tag says late Dec.
    Can anyone tell me why?
    All other trim tag info is correct.
  2. Gary S
    23,928
    1,516
    Are you sure the VIN tag and trim tag are originally from the same car? Without a lot of digging, it is often difficult to determine if a car has been messed with. One way would be to get into the heater area of the firewall and look for the hidden VIN to see if it matches the VIN tag on the car.
  3. Gary S
    23,928
    1,516
    Another possibility is that the original trim tag was lost along the way and a previous owner decided to have a reproduction tag made up. If he didn't have the original information and the reproduction company put the wrong information on the new tag, it wouldn't match the car. This is a problem when reproduction tags are put on a car. Nobody has the 100% correct information to reproduce one if you don't have the original one to copy.
  4. Rich Schmidt
    Rich Schmidt Veteran Member
    4,285
    40
    Mar 27, 2010
    Denville NJ
    I have never seen that big of a discrepancy. I doubt that both tags were born on the same car. One other thing might be to look at the body number on the trim tag but there isn't much to reference on. If I were buying the car this would be a red flag for me.
  5. McCune
    McCune Veteran Member
    1,329
    329
    Aug 22, 2015
    st.george utah
    He posted his VIN on Facebook and it is a 12C car. The vin was the 17344th car built for 73.
  6. badazz81z28
    20,728
    1,417
    Alabama
    Makes more sense someone swapped the VIN tag over the Trim tag...not that its the case here, but amazing how people don't realize what can happen in 50 years...
  7. mallard
    mallard Veteran Member
    1,194
    361
    Oct 3, 2013
    SK, Canada
    Does the vin on the upper left of the dash match the VIN on the sticker on the drivers door? That sticker should have a build date on it. If they match then you’ll know the firewall tag under the hood is amiss.
  8. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,848
    980
    May 21, 2014
    Hutto, TX
    My 73Z is 01E (5th week of January 1973) according to the trim tag, but my VIN door sticker has 2/73.
  9. bodymanbill
    bodymanbill Veteran Member
    1,706
    1,373
    Feb 1, 2007
    South Park Pa
    Mines a 01A and 123459 but my original door sticker date was unreadable
  10. Gary S
    23,928
    1,516
    That makes sense. The 5th week of January would have some January days and some February days. The sticker was printed a day or two after the trim tag was stamped so they add up.
    BillyDean7173 likes this.
