vinyle stripes removel
Discussion in 'Body Restoration' started by camaro6662, Oct 4, 2006.
  1. camaro6662
    camaro6662 Veteran Member Lifetime Gold Member
    769
    Feb 29, 2004
    Jackson Ga
    Just a heat gun plastic putty should do the trick?? any other things I should remember or hints??
  2. bigwilly
    bigwilly Veteran Member
    196
    Jan 1, 2006
    Marietta, Ga
    Razor blade
  3. Tru70SS/RS
    Tru70SS/RS Veteran Member
    1,043
    8
    Aug 13, 2005
    The Inland Empire, So.Cal, USA
    razor blade work well with a little heat from a heat gun.
  4. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    3M has a body solvent / adhesive remover that's safe to use on painted surfaces. It's available in quarts from body shop supplies and I've even see smaller 1/2 pint cans at some Walmarts accross the country.
    Sometimes it helps to apply this on the surface before starting so you can get a corner or section started without damaging the paint underneath. Just soak the surface around the edge of the stripes or decals for a few minutes and then go after it.
    This will also help remove any residue from the adhesives and the "edge" after the vinyl is pulled. The stuff is helpful to remove tacky or oily residue on interiors or other parts too.
  5. A71SS4ME
    A71SS4ME Veteran Member Lifetime Gold Member
    1,164
    Nov 28, 2003
    Ringgold, Ga., USA
  6. camaro6662
    769
    Feb 29, 2004
    Jackson Ga
    Well I did real good up until the paint peeled off in couple of spots. l will just paint the black stripes. just dont have any touch up paint.
    Chris thanks for the link did save it. to all those for the helpful hints thanks.
    sometimes things do go wrong ...
