good question hulk, but I don't see why the stock vavles won't handle it. Don't have the stems cut on the valves, the only advantage I see with going with different valves is to move to a 2.05/1.60 combo and raise the compression a tad since the stocker valves have huge dishes on them.
Dirt, gettin back to that article on porting vortecs.. That 350 made some serious power with the mods!Can we belive these numbers??Thats an awful mild cam too boot...Not too far off the 500 mark.. I'd be real happy with a motor like that.. Hulk
Hardline If I use the above mentioned tools, what seals should I use? Part numbers of the seals as well as whether Summit sells such seals and at what price for a set of 16? Thanking you in advance.
Here you go: http://store.summitracing.com/partd...859070+4294863000+4294789320+115&autoview=sku These are the ones I've used in the past.
It looks like I get to join your vortec fun now as well. I believe I am starting with a 383 with stock vortec heads. I bought the car as is, so I don't really know what work was done to the heads. I have 1.5 roller rockers and a comp cams 280H. Is there any way to tell if I'm ok with my cam on the vortec heads? I have some timing issues to work out first (49* advance at 1500 rpm....) but after that I want to make sure the valvetrain is still in good condition.
Well guys I'm completely new to this forum, but want to thank 73 Deville for introducing me to this site I am currently building up a 72 El Camino, and recently got my hands on a 350/5.7L Vortec machine, currently feul injected but I am going carburated on it. Currently looking at installing the Edelbrock performer RPM Air-Cap intake with a 650cfm carb. I will propably be bugging you guys a lot for more information as this is my 1st buildup I'm doing
What are you refering to when you ask if you're ok with your cam? Performance, lift clearance, vacuum etc.? If your clearance wasn't enough you'd probably have a lot of bent pushrods, smashed valve seals and pulled out studs.
Welcome! I love Elky's and my little brother is obsessed with getting one. The RPM air-gap is a good intake and made the most power compared to all other dual-plane intakes in al the tests I've seen. Your carb size seems adequate too dpending on the cam you plan to use. For a stock Vortec cam it might be a little much.
Thx for the welcome Hardline would you rather advise me to go for a 600cfm carb with the stock Vortec cam, another question I have is this. Seeing as I am going from fuel injection to carburetted I will need to replace the distrubutor, planning on installing a 14" airfilter. So would like to know what would be a good distibutor, I am for the moment leaving everything stock accept for the fact that I am going carburetted. I will post some pics of what everything looks like now and then will post pics when I am done with everything Any advice would be highly appreciated
