Vortec heads
Discussion in 'Engine Topic' started by Thomas Mihalyi, Mar 30, 2020.
  1. Thomas Mihalyi
    Thomas Mihalyi Member
    35
    Aug 26, 2019
    I just got some Vortec heads from a junk yard and didn’t realize til I was taking off my stock heads off my 1977 camaro that there are 6 bolts on my intake but only 4 on the Vortec heads can I still use this intake or do I absolutely need a new intake
  2. Green hornet
    Green hornet Veteran Member
    1,845
    375
    Oct 11, 2015
    North Bay, CA
    You will need to buy an intake that fits the Vortec heads. Not only are there fewer bolts but the bolts are at a different angle.
  3. 1980RS
    1980RS Veteran Member
    3,896
    837
    Jun 17, 2006
    MN
    Hornet is right you need a intake made for Vortec heads. While you are at it put some good springs on the heads and don't go over .480 lift, maybe less.
  4. frank5s
    frank5s Veteran Member
    191
    Sep 6, 2008
    Naperville Il
    I picked up used vortec heads at local boneyard, then installed ls6 beehive springs, got some comp cam retainers that added
    +.050 clearance and also valve locks that added +.050. Heads made big changes to stock 1980z 350 engine.
    tom3 likes this.
  5. Thomas Mihalyi
    35
    Aug 26, 2019
    Thank you for all the responses I have one more question and do I need a certain head gasket or will any sbc one for my engine work
  6. Thomas Mihalyi
    35
    Aug 26, 2019
    I also am running heads from a 5.7 to a 305 I’ve seen that it works okay
  7. Green hornet
    1,845
    375
    Oct 11, 2015
    North Bay, CA
    No problem on the heads to a 305. As for the head gasket get a head gasket set that fits The Vortec heads, it will come with the intake gaskets that you need. They are also different like the intake manifold.
  8. Thomas Mihalyi
    35
    Aug 26, 2019
    Okay thank you so much everyone
  9. Thomas Mihalyi
    35
    Aug 26, 2019
    I get a head gasket for a 5.7 because my heads are from one correct
  10. frank5s
    191
    Sep 6, 2008
    Naperville Il
    Use a steel shim gasket , it is .016 thick and help raise compression
