What about Bazooka bass tubes make them not so good?
Discussion in 'Car Audio, Electronics & Security' started by sunkenloot, Mar 10, 2015.
  1. Coadster32
    2,259
    357
    Oct 2, 2013
    Milford,CT
    I had a couple back in my day in the trunk. I thought they sounded good.
  2. RJ45
    RJ45 Veteran Member
    243
    Nov 15, 2012
    Whitehouse Station, NJ
    I had one back in the early 90's in my 1990 GT Mustang. I liked it a lot. Very good bass for hard rock.
  3. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    I have a 10" (no amp) that I've had for years. I took the woofer out and put it in a box and let my buddy hook it up. He got the wires on the voice coils crossed and that lasted about 20 seconds.
    Since then I replaced with woofer with one of their older subs, SVC models. It still hits hard as hell. Right now it's in my friend's bar with an old Alpine 3527V being powered by a 15 amp power supply, running the tube and a pair of bookshelf speakers. It's loud enough to piss of the neighbors on a late Saturday night. :D
  4. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,983
    10
    May 22, 2001
    Carmel, NY
    I have a self powered 10" bazooka in my daily driver. It works great for what it is...cheap and easy.
  5. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    I was a Bazooka dealer, and sold Pyle when they were a better brand than today, but the Bazookas stayed good and improved their line up.
    The amps are weak if you want break windows with urban rap etc.
    If you are boosting a factory system (newer vehicle) the extra deep bass extension is noticeable.
    The 8" and 10" powered, a pair of them corner loaded in a Camaro sound quite good, or can be felt. You do notice them.
    Just one powered 6" bazooka, corner loaded, behind the seat of a reg cab PU made a HUGE difference.
    If you attach bass blockers to the 6x9's and the front speakers, then adjust the crossover to the same level on the powered Bazooka you get the best sound and volume.
    Using your amp on a Bazooka, works as well as any other sub up to its power limit. just make sure they are loaded into a corner.
    I may have a Bazooka or two left in old inventory I'd sell for less than new internet (ebay, Amazon) prices.
  6. 75Camaro4x4
    75Camaro4x4 Veteran Member Lifetime Gold Member
    345
    Aug 5, 2013
    Wilson, NC
    I have had a few road master tubes in the past given to me. 10/10 would not recomend those.
    An option a friend of mine uses, is the NVX QuickBass system, and he has connectors from tractor supply to make the amp easily removeable. The connectors would be a good idea on any amp that is removed often.
  7. sunkenloot
    sunkenloot Veteran Member Gold Member
    221
    Aug 30, 2010
    Dallas, TX
    I ended up getting a Kicker hideaway. I mounted it on the back of the seat in the trunk. Sounds real nice at normal volume but, once everything gets loud I cant hear it anymore. Here is how I solved the rest of my problem. I know this isnt a standard solution but, Im very happy with it.
