What are these parts 2.0
Discussion in 'Camaro Questions' started by VA/SC Gamecock, Jun 5, 2020.
  1. VA/SC Gamecock
    VA/SC Gamecock New Member
    9
    Apr 30, 2015
    Danville, VA
    Hey guys. You helped me a lot earlier with some parts that I had acquired in a massive lot of parts that were included with a 72 Z car purchase. Here are 4 more that I cannot identify what they are and if they are even 2nd Gen parts or not. Any help would be awesome. thanks!
  2. BillyDean7173
    BillyDean7173 Veteran Member
    2,102
    609
    May 21, 2014
    Hutto, TX
    The two top pieces are exhaust heat shields. Hard to find and can be expensive. The longer one is for the RH side and the shorter one for the LH side. The RH one goes up the firewall a little and under the floor. The LH one just goes under the floor. There should be brackets on your car for these shields to attach to.
    I don't know what the bottom two pieces are.
    VA/SC Gamecock likes this.
  3. VA/SC Gamecock
    9
    Apr 30, 2015
    Danville, VA
    That's great info BllyDean7173. Thanks a lot! Hopefully someone else may know about the other 2, thanks again
    BillyDean7173 likes this.
  4. VA/SC Gamecock
    9
    Apr 30, 2015
    Danville, VA
    Here a close ups of the other 2 parts not identified yet.
  5. BillyDean7173
    2,102
    609
    May 21, 2014
    Hutto, TX
    When I bought my 73Z, it was a basket case and I only had the short LH side heat shield. Almost threw it out because it looked like baseboard on the walls in a house. I thought there was no way that could be for the car. Glad I didn't toss it.
    Someone else here may be able to tell you what years and options they were for. 72 and 73 Z28s would be two that I know of. Not sure about 72 SS. 71 I'm not sure about. 70 Z28 didn't have them. Don't know about 70 SS. That's all I know.
  6. twestrup
    twestrup Veteran Member Lifetime Gold Member
    223
    115
    Aug 22, 2018
    St. George, Utah
    IMG_4989.JPG IMG_4989.JPG IMG_5473.JPG The left one goes in the heater box I believe.
  7. VA/SC Gamecock
    9
    Apr 30, 2015
    Danville, VA
    Thanks twestrup. That definitely looks like it.
  8. flint9
    flint9 Veteran Member
    113
    9
    Jun 6, 2016
    st louis mo
    the one on the right looks like wire/holder bracket, can't quite place it.
  9. BillyDean7173
    2,102
    609
    May 21, 2014
    Hutto, TX
    Agreed. It reminds me of a throttle cable bracket with the fork at the end, but I've never seen one made of thin aluminum or stainless.
  10. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,356
    84
    Jan 1, 2005
    Schererville,In.46375
    Heat shields thru 74 Z28’s.......
