What are these screws for?
Discussion in 'Body Restoration' started by VandykeT/A, Sep 25, 2021.
  1. VandykeT/A
    VandykeT/A Member
    85
    Feb 11, 2012
    Hurley, VA
    They weren’t holding anything just screwed into the wiper cowl it’s an 80 113AB83A-B421-4F64-B9DD-9912643B3B43.png
  2. badazz81z28
    21,142
    1,509
    Alabama
    Doesn't look factory to me... Maybe your cowl was sliced (which it looks like), someone put a screw to hold it down?
  3. VandykeT/A
    VandykeT/A Member
    85
    Feb 11, 2012
    Hurley, VA
    What do you mean sliced? Here’s a picture of it from a distance. I can’t tell anything in that area has been cut on before. I’ve owned it the last 18 years. They’re no metal capped from underneath and it had one other of those on the passenger side. 84D73128-C45E-4063-A251-91A5972985CD.jpeg F0BC9EB1-DCC0-490A-A9C2-F4C61897C393.jpeg
  4. MChamp
    MChamp Veteran Member
    410
    112
    Jun 6, 2021
    north carolina
    whats left of the cowl vent cover?
  5. l16pilot
    2,099
    263
    Dec 13, 2004
    Hurlock, MD, USA
    Looks like the screw that held a spring-steel grounding strap. The grounding strap had teeth on the end and grounded the hood to the cowl. Looks like the below item
      File size:
      3.2 KB
      21
  6. VandykeT/A
    VandykeT/A Member
    85
    Feb 11, 2012
    Hurley, VA
    The cowl cover is actually in really good shape. These screws were in front of it. The ground strap was there (didn’t know that’s what that was) it was held on with a 8mm screw. These were off to themselves on both sides of the car not holding anything.
