What brackets are you using for ls swaps with AC/vintage air
Discussion in 'High Tech Retrofits' started by AllensaurusRex, Jul 20, 2015.
  1. AllensaurusRex
    AllensaurusRex Veteran Member
    544
    32
    May 22, 2013
    Murfreesboro TN
    Is anyone out there using a certain set of brackets on the F body/ls swap Camaros that have AC? I know the way my vehicle sits there is absolutely no way I could utilize the original AC brackets from my ls6. See below.
    Anyway, what are you guys doing? Please point me to a thread if I have missed it. Thanks!
    http://www.rickscamaros.com/corvette-ls-engine-air-conditioning-bracket-kit.html <-- Kinda pricey though..
  2. jthomas
    1,693
    183
    Dec 5, 2007
    NorthCentral PA
    I can't answer your question...just had to say I'm really jealous of those AFR heads. Those look great!
    By the way, if you haven't already found out, your going to love those Speed Tech control arms. I've had mine for 5 years now and they are great arms. You can get a full 4-5 degrees positive caster and the negative camber you need with hardly any shims.
  3. AllensaurusRex
    544
    32
    May 22, 2013
    Murfreesboro TN
    I'm still renting because I can't save up for a house with this thing in my name...basically putting off my life to build her haha. Thanks.
    Also, I'm super excited to see how they feel and adjust the recoil/etc. I plan on taking her around the U.S. to shows/on road trips so hopefully won't be too boisterous and harsh of a ride. Then again....I did put in a .617 lift CAM. We will see haha.
  4. DENALI
    DENALI Veteran Member
    1,099
    19
    Nov 4, 1999
    Sonova Beach
  5. MartyO
    MartyO Veteran Member
    290
    Sep 7, 2014
    Hiram, GA
  6. Chris71RS
    Chris71RS Veteran Member
    491
    Feb 26, 2006
    An Island called "long" in the north atlantic
    Another KwikPerf user here...
  7. DENALI
    1,099
    19
    Nov 4, 1999
    Sonova Beach
    Actually I would be inclined to go with this ITC BILLET A/C Bracket for $118 and save a lot of coin over the Kwik. I would also use their alt bracket for $118 as well
  8. AllensaurusRex
    544
    32
    May 22, 2013
    Murfreesboro TN
    Awesome. Thanks!
  9. speed_m5
    speed_m5 Veteran Member
    1,102
    27
    Apr 17, 2010
    Baytown Texas
    I used the kwik brackets also but did not the fact that you must trim the inner fender well for it to fit. I went with The vintage air front runner kit for the LS
  10. DENALI
    1,099
    19
    Nov 4, 1999
    Sonova Beach
    Havent heard of anyone else having to trim?
