What could cause the rear to sit lower on one side?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by JWZ28, Jan 29, 2016.
  1. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    The driver side rear of my 78 sits a good bit lower than the passenger side. What could cause this?
    Rear suspension:
    Summit lowering springs
    Poly spring pads
    Addco anti-sway bar
    Moog shocks
  2. CorkyE
    11,434
    935
    Sagging springs.
  3. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    I installed the springs about six yrs ago new from Summit, but they are a cheap spring. I guess it's time to order hotchkis, or is there another good brand that won't hurt the wallet too bad?
    Also, where can I get the correct spring bushings for the rear eyelet? The all the ones I've tried were incorrect.
  4. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    Did you torque the suspension with the car in the air? You should have it sitting level on the ground and bounce it around a few times before tightening all the fasteners. Also, the poly spring pads have been known to slip out of place if the car is driven haard on occasion. I got my springs from a local shop and no issues. the rear eye bushings came from Keith at Custom Works. Good luck.
  5. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    The car was on the ground before i tightened the suspension. I did tighten the front bolts on the leaf springs before dropping it. I cant reach them once on the ground. Ive checked spring pads and they seem to be in place.
  6. Brown`77Z28
    Brown`77Z28 Veteran Member Lifetime Gold Member
    1,337
    Dec 11, 2005
    The Netherlands
    It could be the body itself, I had the same problem with my '77
    I even swapped my springs from left to right and back but it didn't helped a bit.
    After that I started measuring the body and it turned out that my RH quarter panel sits a good 1" lower on the body.
    It turns out there was a large margin when they assembled our cars.
  7. BonzoHansen
    20,898
    1,862
    Jun 1, 2005
    Scott from Hamilton, NJ
    ^^^yes
    is the front off too?
  8. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    No the front is fine. I considered this as a possibility, they didn't mind the gaps and what not on these things even from the factory. So if it is the body, are there any options?
  9. falloutboy
    falloutboy Veteran Member
    2,283
    15
    May 1, 2003
    Grafenberg, Baden-W├╝rttemberg, Germany
    are the values D and Z the same for left and right?
    And what are the values?
    A broken leaf may also cause a saggy side
  10. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    I've checked the leafs and nothing appears broken. I'll try to measure today when it warms up, but the car is lowered so the values may not reflect what the diagram shows.
