What Engine/Tranny Combo is most cost effective?
Discussion in 'Engine Topic' started by Quazit, Jan 6, 2022.
  1. Quazit
    Quazit Veteran Member
    271
    88
    Feb 23, 2021
    Dallas, North Carolina
    Ok, odd title I know.
    I have the 75 which I will be putting back together in the next 6 months or so.
    It has no driveshaft, no transmission or engine in it, so I see it as a blank slate.
    If I were to source a used engine setup. What would people recommend? I would like the build or setup as economical as possible when the time comes. It will likely just be a day cruiser.
    If there is a donor vehicle I should be looking for parts from in local yards I'll take that information also. I prefer not to change the mounts and stick to what would be able to drop in with the least modification as possible.
  2. tom3
    tom3 Veteran Member
    13,922
    1,449
    Aug 1, 1999
    ohio
    Go find an 70s or 80s GM car or van with a V8 that is ready for the crusher and pull the drive train. Used to be pretty common here in the snow belt to find a decent running pile of rust for a couple hundred bucks. Clean up the motor, tuneup, some chrome and go with it. Might find a 4 speed auto even. Scrap the vehicle and recover some of the cost.
    1320feet and Quazit like this.
  3. 1980RS
    1980RS Veteran Member
    5,741
    1,951
    Jun 17, 2006
    MN
    400 SBC, with a set of Vortec heads and a good Turbo 350. That combo will bring a smile to your face for sure.
