What gauge order/position
Discussion in 'The BS Topic' started by muscl car, Jul 6, 2020.
  1. muscl car
    22,899
    1,467
    Jul 8, 2001
    SoCal High Desert
    If you have a 3 gauge aftermarket set up , What is your preference for gauge position from left to right . If you had oil pressure , water temp and transmission temp ???
    Right now my old SW gauges are from left to right
    Water temp
    Oil pressure
    Transmission temp
  2. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    232
    175
    Feb 5, 2016
    Sarasota,FL
    I like to position them in order of importance, most important closest my viewing angle.
    Oil pressure, Water Temp then Trans Temp.
    roadrace2, 79RedZ and muscl car like this.
  3. 79RedZ
    79RedZ Veteran Member
    763
    74
    Mar 24, 2009
    Hamilton,MI
    I always have had oil pressure closest to my view. I also have a mini pro-light on my steering column with a 15 lb pressure switch.
  4. COPO
    19,618
    1,703
  5. Twisted_Metal
    28,457
    1,778
    Alphabetical order is the only way that makes any sense.
    dave@ztech likes this.
  6. ULTM8Z
    ULTM8Z Veteran Member
    9,722
    714
    May 19, 2000
    Los Angeles
    I organized my gauges by category...
    To the left of the speedo and tach, I have "levels"... fuel level and volts (voltage level). To the right of the speedo and tech i have temperatures... water and oil temperature.
    In my three gauge cluster I have pressures... from left to right... manifold pressure (in the form of a vacuum gauge), oil pressure, and fuel pressure.
  7. G72Zed
    G72Zed Veteran Member
    2,053
    868
    Sep 8, 2015
    My line of thinking follows right along with 70Znut & ULTM8Z.
    Temps on the left, pressures on the right. And taking consideration the "race" cars that clock the gauges based on preferences, I like these gauges because it gives me the info without "looking" at them, I'm cold/low between 9 & 10 O'clock, good between 11 & 1, and concerned at 3 O'clock LOL.
    The race cars I tune on do not even have a Tach now !!!, Oil pressure & Temp, Water Temp and pressure, 4 gauges, nothing else !!
  8. dcozzi
    dcozzi Veteran Member
    3,831
    901
    May 1, 2002
    Phoenix, AZ
    I would stick with that.
    Overheating is more common and will jack a head gasket.
    Oil pressure usually is looked at at fire up then, not so much.
    Trans would only be looked at by me if something did not "feel' right with it's operation.
    If you are drag racing, you look at all of them so order does not matter so much.
    muscl car likes this.
  9. theflash
    11,044
    36
    Feb 27, 2004
    Podunk, CT
    2 pair, water temp, oil psi, and wideband A/F, volts
  10. muscl car
    22,899
    1,467
    Jul 8, 2001
    SoCal High Desert
    I decided to go ..... Water temp , Oil pressure , Transmission temp and these gauges are big enough I can easily see them
