What goup to buy for kick panels?
Discussion in '1978 - 1981 Specific' started by JD Z, Jul 1, 2019.
  1. JD Z
    JD Z Veteran Member
    246
    17
    Aug 18, 2017
    Shawnee Kansas - Kansas City MO area
    I took out my kick panels and will be putting in speaker kicks. I’ll need some of that black goup to seal it all back up. What might I get at HomeDepot or Lowe’s...or online. It’s like tar stuff.
    Thanks gents.
  2. 70 Proof
    70 Proof Veteran Member
    571
    65
    Sep 28, 2014
    Southern Utah
    There is a light grey modeling clay like substance that that is somewhat, comes in a roll and you can tear off what you need, Its commonly used by some rv manufactures to seal around the edges of roof vents. I used it to adhere the water shield to my camaros door panel and the military uses (or used to)it to seal some of the windows on helos. I believe the military called it zinc chromate paste. You ought to be able to find it at most hardware stores. If you definitely want something black there is Xtreme T.ape that is very sticky and relatively thick compared to gorilla tape and others. I bought a roll at Classic Industries a while back- good stuff.
    .d
    JD Z likes this.
  3. 70lt1z28
    4,440
    1,057
    Oct 3, 1999
    Beavercreek, Ohio, USA
  4. JD Z
    JD Z Veteran Member
    246
    17
    Aug 18, 2017
    Thanks guys. I was heading to Home Depot already.
