what headers for a lt1,w/AFR 227's
Discussion in 'High Tech Retrofits' started by purpleflame, May 16, 2008.
  1. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
    I am in the stages of putting the motor together and started thinking about headers and what will fit, i have a set of jet hot long tubes but they are for a 95 firebird dont look like they will fit might touch the frame. so what headers should i look at getting i have my stock dynomax headers from my old motor but they arent pretty enough.
  2. 1981LT1
    1981LT1 Veteran Member Lifetime Gold Member
    549
    104
    Dec 15, 2004
    San Antonio, Tx, USA
    I went with the Summit brand coated headers for my 81 camaro. I have since upgraded to Hedman coated headers. Either way, you should match the headers to the chassis so they clear the proper interference points. Don't worry about the D port exhaust outlets, normal round tube headers will seal perfectly fine and I only had to slightly dimple of the tubes for the angle plugs. It was almost too easy:cool:
  3. purpleflame
    234
    May 7, 2003
    I have square port heads not D ports but I am assuming the gen 1 headers look to fit. will just test fit them tonight.
  4. 3_z28camaro
    3_z28camaro Veteran Member Lifetime Gold Member
    4,448
    Dec 17, 2004
    Acton, CA
  5. purpleflame
    234
    May 7, 2003
    K I finally got the header thing figured out I am gonna run thesethey are very nice might jet hot coat them but who knows every set Ive seen that are coated turn colors anyway. So this is them they are actually for circle track camaros DYNATECH STREET STOCK HEADERS - 1.750" DIAMETER - STANDARD CHEVY FLANGE - 3.00" COLLECTORS - FITS 1970-80 CAMARO CLIP / 1964-77 CHEVELLE CLIP - #DTH01-21000 $350 shipped to my door.
  6. Christian GM
    Christian GM Veteran Member
    146
    Jul 14, 2007
    Italy
    Did you install it?
    I'm interested in the ground clearance too...
    here there are tons of "speed bumps" on the road:
    Also my garage has a nice ramp to do:
    thanks!
  7. Christian GM
    146
    Jul 14, 2007
    Italy
