What is the vacuum canister behind my headlight?
Discussion in '1970 - 1973 Specific' started by Millwright, Jun 7, 2019.
  1. Millwright
    Millwright Member
    52
    22
    Mar 30, 2019
    Ontario Canada
    What is the vacuum canister behind my driver side headlight. My PVC valve is a T and connects to it. Was going to replace my PCV valve then noticed it was not the setup I was expecting.
  2. Zspoiler
    Zspoiler Veteran Member
    3,768
    359
    May 6, 2012
    Federal Way, Washington
    Its a charcoal canister .It lowers emissions by drawing the fuel vapor from the gas tank to the carb to be burned in the engine. It helps fuel mileage a little as well. Some people remove them for a "cleaner" look .But is more hassle to do so. So I left mine alone .
  3. Coadster32
    2,086
    273
    Oct 2, 2013
    Milford,CT
    Some people get rid of it...and then later complain about their car smelling like fumes.
  4. Millwright
    Millwright Member
    52
    22
    Mar 30, 2019
    Ontario Canada
    Bit of a follow up question...
    I was going to replace my PCV valve. The connection on my PCV valve is a T. One side of the T goes canister I was mentioning before. That seems to make sense with how everything should work. So my question is why does everywhere I go list a straight standard PCV valve for a 73 Camaro? Its like this system didn't exist. Clearly from the responses above this is a normal thing to have in this car.
  5. Coadster32
    2,086
    273
    Oct 2, 2013
    Milford,CT
    Check out some factory drawings on the car. Maybe factory was a standard PCV with a T somewhere down the line, and was switched out. (After all...it was 46 years ago).:D
  6. CorkyE
    10,975
    717
    Don't know for sure if this is what you're referring to but many (GM) pcv valves have a universal inlet design and the plastic fitting, be it a tee, a 090, or straight, is put on at the end of manufacturing. Last one I bought was straight so I pulled the 090 fitting off the old one.
  7. RS1979
    3,973
    916
    Jun 18, 2013
    Memphis, TN
    You can heat it up where it attaches to the valve with a lighter and it'll come off. Then put it on the new one before it cools.
