What is this? Need a quick answer.
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by tskills10, Feb 27, 2018.
  1. tskills10
    tskills10 Veteran Member
    210
    Dec 1, 2007
    painesville, OH
    Have a 70 RS with front disc. I'm installing a line lock. And looking at the brakes I'm not sure what these 2 blocks are. The front line comes from the M/C into this cast block, which has a rubber button on the back, and from this block into the proportioning valve.
    The brass block has a line from the p-valve to the block then back into the p-valve. Not sure what these are.
    As for the line lock, should I go between the m/C and the block or between block and p-valve?? Need a quick answer, trying to finish this today.
    Thanks for the imput
  2. Twisted_Metal
    30,194
    2,900
    You have a Metering valve (circled) and a Proportioning valve.
    Later systems used a Combination valve.
    Sorry... I don't know the best place to put the line lock in this system.
  3. badazz81z28
    21,142
    1,509
    Alabama
    Get rid of both and get an adjustable prop valve. Then install a line lock
    budro6968 likes this.
  4. ronzz572
    2,417
    232
    Feb 8, 2007
    imperial pa
    The larger bowl of the master cylinder feeds the front brakes. Use the line out of the master cylinder for the line lock solenoid.
  5. budro6968
    budro6968 Veteran Member
    4,036
    800
    Apr 2, 2016
    Jax Florida
    Have not seen that do hickey.
