What is this upper door panel?
Discussion in 'Interior Restoration' started by 73RATTYZ28, Jun 30, 2020.
  1. 73RATTYZ28
    73RATTYZ28 Veteran Member
    494
    30
    Feb 23, 2001
    White Plains NY USA
  2. Camaro Tim01
    Camaro Tim01 Member
    60
    8
    Jun 8, 2020
    Bradenton, Florida
    unsure of your question ??you mean make/model it comes from because its exactly what you said it is, the upper door panel... LOL
    Back when I was a young kid I had a '70 SS and 2 years later a 73 RS ( not that I grew up rich or priveledged, quite the opposite, dirt poor and broke and they were both rust buckets that if remembering correctly I paid $300 and $500 for at the time ).... They both had those upper door panels and then one middle panel of vinyl and a plastic panel that went to the bottom of the door.
    throughout the years the styles changed from 3 piece to 2 piece to 1 piece panels.
    From the look of the mirror adjuster being square and I think I see a bottom plastic piece for the door, I think its from a '70 73 model
    Best bet is to look through online catalogues to narrow down exact years like camaro central, NPS, ecklers, ricks camaros ect...
  3. 73RATTYZ28
    494
    30
    Feb 23, 2001
    White Plains NY USA
    So I assume that chrome bezel is for the remote mirror. Is the passager side interchangeable with earlier models?
  4. Camaro Tim01
    Camaro Tim01 Member
    60
    8
    Jun 8, 2020
    Bradenton, Florida
    Camaro Central lists 70-75
    Classic industries lists 70 -73
    Ricks camaros lists 70-73
    Thinking back and picturing my 73 RS, I was incorrect, that square mirror adjuster I had on it so it should fit fine if its a 73 you have as your name implies.
    they should be interchangeable and fit 70-73 models, not sure why camaro central lists up to 75,might or might not be but yes thinking back both my 70 and 73 had them and were the same... I remember because the plastic bottom portion on my 70 was notorious for coming unclipped from the middle portion and I removed both and made a white leather panel that went into the piece you took a pic of, looked awsome white on black...LOL
  5. dave@ztech
    4,083
    885
    Mar 27, 2016
    NY
    Usually the mirror remote is in the middle panel not the top piece
  6. 73RATTYZ28
    494
    30
    Feb 23, 2001
    White Plains NY USA
    It's on the middle piece of my 73. I have never seen one on the upper panel. I just need the passenger side as mine is cracked.
  7. BillyDean7173
    BillyDean7173 Veteran Member
    2,124
    627
    May 21, 2014
    Hutto, TX
    Dave is right. It may fit, but that's not factory.
