What product do I use to paint dash/cowl area?
Discussion in 'Body Restoration' started by 76_TypeLT, Jul 16, 2014.
  1. MotionClone
    MotionClone Veteran Member
    1,479
    303
    Jan 20, 2014
    away from the crazies
    I did the same thing Krabben did. Satin Hot Rod black Urethane single stage from Summit over SPI Epoxy. I put the paint on kind of textured. I'll try to post up a pic tommorow.
  2. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    my main concern with this is the glossyness of the SPI epoxy primer. I suppose I could top coat with a satin clear coat?
  3. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    thanks, I'd love to see how it turned out for you
  4. 1981blackZ28
    1981blackZ28 Veteran Member
    157
    Oct 2, 2010
    Knoxville, TN
    My metal dash was partially chemically stripped by the previous owner. Since I wanted to go back with the factory color I looked at the interior color code chip pages and found some of the codes had an * denoting low gloss. I ordered online a custom mixed aerosol can of PPG lacquer which looks to be an exact match to what was left on the dash and also to the metal trim at the back of the package tray.
    The GM color chip page also states that "intsrument panel color must be sprayed with UCV-69 low gloss clear"
  5. modracer
    modracer Member
    41
    Jun 30, 2014
    Gainesville, Ga
    Mine usually comes out real glossy when I am using it just for primer but I lay it on real thick and wet. A friend of mine shoots a lot of it and cant believe the gloss of mine as his always looks like the color or lower gloss that you are looking for. He does reduce his so not sure if that is the difference or not but if you called Barry or sent him an email he could probably tell you.
    I have gotten that satin look before but don't remember what I did differently that time.
  6. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    I might do that, thanks.
    I am leaning more toward using either a Hot Rod black product like others did or use SEM Landau Black for consistency. I love SPI epoxy primer but I don't think it would generate the look I am after.
  7. MotionClone
    1,479
    303
    Jan 20, 2014
    Pic makes it look glossier than it actually is but here is Hot Rod Black Satin Urethane:
  8. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Thanks, that is really helpful. It gives me a good idea of what that product finish is like.
