patroll
I have a 1975 Camaro removed the old VIR and installed VIR eliminator kit, changed the compressor to a A6 or S6 the one that looks like it's aluminum on the back section but bolts up like the original one, Flushed the evaporator and condenser before doing this and covering the ports to keep moisture out. Had the original hoses fitted with the non leaking style for R134A refrigerant changed the o rings .( PROBLEM STARTS HERE) the head pressure or high side gets around 250ish the low side gets around 60 degree coil . works good when it's raining which I prefer not to drive in. I need to lower my original condenser pressure /heat down , can anyone give me the proper measurements any tips on a pusher fan to mount to the front of the condenser to lower my high pressure down ? I'm a home HVAC mech. this car has been different , know that there's a after market condenser but you have to change the hoses to . Trying to keep my car as close to original, will use LED bulbs , and some modern things but please help with the reversible/ pusher condenser fan motor. Had a 100 lbs. of R12 wished I would have kept it now.
