trying to grind down some welds in a tight spot whats the best thing to use to do that?
Jul 25, 2019 #1 tims78camaro Veteran Member Aug 6, 2008 608 louisville ky trying to grind down some welds in a tight spot whats the best thing to use to do that?
Jul 25, 2019 #2 B budro6968 Veteran Member Apr 2, 2016 4,185 Jax Florida What are you doing? Maybe some pic's.
Jul 25, 2019 #3 bodymanbill Veteran Member Feb 1, 2007 1,833 South Park Pa Get a belt sander and 80 grit belts, we use them every day here at the shop.
Jul 25, 2019 #4 351maverick full time Ebay seller/hustler/car killer Aug 11, 2010 3,930 erie, PA I agree with the narrow belt sander...it's the only way
Jul 25, 2019 #5 dcozzi Veteran Member May 1, 2002 4,752 Phoenix, AZ I have used a die grinder or Dremel with a stone or sandpaper roll.
Jul 25, 2019 #6 B berg2695 Veteran Member Nov 13, 2011 658 dcozzi said: I have used a die grinder or Dremel with a stone or sandpaper roll. Click to expand... Yup. A carbide burr would be good.
